Cooling system ?
Old Apr 29, 2002 | 09:22 AM
DMATESIC's Avatar
Cooling system ?
I recently installed a new 3 row brass/copper radiator. The car runs cool with no overheating problems. I did notice that when the car is off and cooling down, the upper radiator hose seems to collapse. When it is completly cool the hose is no longer collapsed. Is this normal? The hose is new and so is the 16 lb. radiator cap. Any thoughts?
Old Apr 29, 2002 | 09:42 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Mine does this too, but only the bottom hose. You should change the top hose because when the car is off, the coolant still circulates (heat soak) .
They usually put a spring inside the hose to keep this from happening.
Old Apr 29, 2002 | 09:54 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I think someone said to check your radiator cap to make sure it's holding pressure. Mine doesn't collapse, that I know of.
Old Apr 29, 2002 | 10:15 AM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i spent $100 for be cool hoses from summit(summits brand but be cool makes em , alot cheaper) anyway, the metal hoses dissipate heat alot better and theyll last the life of the car.....just a suggestion
Old Apr 29, 2002 | 01:01 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Did you get all of the air out of the system? And since you have a new rad. cap, I dont think it is that. Unless it leaks or something.
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
64goatman
Sep 9, 2015 01:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
