Need help to specify an AFR head
Old Apr 30, 2002 | 12:09 PM
primo's Avatar
I need help to specify an AFR 190 head for a 350 TPI for an 87
Iroc. There is some extra machine work needed on the heads for a TPI unit , if you had ordered before please help.
I may used this heads on a stock 350 L98 block or a 383 strocker 1971 block, 4 bolt main.
Thanks for your help,
Old Apr 30, 2002 | 09:00 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You have listed two totally dofferent engines, and most likely two different build options.
I'd say call/email AFR, tell them your itended goal and engine specs, and take their advice...
I/e a 64cc head may be 10:1 on your pistons for a 350, but to achieve the same CR on a 383, you may have to spend more $$ for the same CR than you needed to, if you had the heads milled for the 383 pistons.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
