putting in new 1-peice rear seal
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey gusy i ran into a little problem tonight while startin to build up my 350.ok well i put the crank in and went to put the rear main seal on(one-peice) and in my haynes manual it says u need a speacial tool to do this because it needs to be expanded. well i see wut they mean but is there any other way? liek sum conventional tools i could use? well thanks also would pep-boys have this tool ya think?
I bought a felpro seal for a 4.3 V6 the other day and it came with a sleeve to make installation easier but that is the only part # iI have bought that had it. I allways check for burrs on the end of the crank and if none I lube it and the ID of the seal with Lubriplate 105 and work it on. I have never had a problem with leaks.
Lonnie
Lonnie
Car: yep
Engine: uhuh
Transmission: sure does
As stated above...lube the inside of the seal real good....do not put anything on the outside of the seal.
Just start in one corner and roll the inner lip around while pushing it in.
Once it starts all the way around..take a small hammer and lightly tap it fully into place.
Piece of cake!
Piece of cake!
Guest
Posts: n/a
Yea, I always do what engineboy does, roll it around the end of the crank to get it all on and in place. Putting the seal in the housing itself is easy, get a flat piece of wood (or similar) and just press it in by hand, making sure you are pushing it in straight and not crooked.
Car: 89 Formula
Engine: Carbed 5.7
ok well i already have the seal inside the houseing thing so is there anyway i can still put it on? can i just use the method u guys are talkin about?
Car: yep
Engine: uhuh
1992 Trans Am
May 10, 2023 07:19 PM
