what do front and rear sway bars look like?
what do the front and rear sway bars look like? im not sure if i have them, because ive never seen one before that i knew was one, so what do they look like? where are they located, i have two bars on each end of my car, but i dont think they are sway bars.
Transmission: 4L80E/4L80E
They are shaped like a fat "U", and go from one side of the car to the other.
I've never heard of a 3rd gen without a front sway bar, but it is linked to the lower control arm on each side by a long bolt with rubber donuts on each end. It is held onto the frame rail on each side by a rubber bushing with a flat metal U-clamp with two bolts to the frame rail.
The rear bar is smaller in diameter, and runs along the bottom of the rear axle. It's held to the axle with similar rubber bushings, and each end is held to the body by the long bolts w/rubber donuts like the front, to a bracket on the body behind the wheelwell.
Hope that helps. My V6 car didn't have the rear sway bar, but the one on the V8 donor car lives there now.
Car: 1986 Firebird
Engine: 2.8 V6
Yep, just look under your rear axle, if there's a bar under it that runs from left to right, that's a sway bar. Similar one is under the front. Go to http://www.summitracing.com and go to the chassis section, and look up swaybars, they must have pics there.
1992rs/ss
Jan 31, 2025 05:10 PM
ambainb
Apr 25, 2016 09:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
