View Poll Results: Which fuel delivery system?
non stock TBI
8.33%
Carburated
91.67%
Voters: 12. You may not vote on this poll
TBI<-->Carburated --> 327cid
Old May 2, 2002 | 01:10 PM
Bird_of_Prey's Avatar
Car: Formula
Engine: 400 sbc
ok, i have a problem... *cough cough*
well.. actually, after of thinking about it, i'll make it a real problem..
a 327... i've got the tpi of my car that i can use.. but i'll either have to make extensive modifications.. or just put on a mini ram to get that thing to spool up quicker and actually suck something through the plenum @7000 rpm..
but i don't feel like spending over a grand on a super ram or mini ram.. (being somewhat cheep here.. would rather spend it on suspension/drivetrain then get a mini ram)
now, would a TBI work with this? lets say i got one off a 454 or something like that..
or should i go carburated with either a dual carb setup (like two 370 cfm or so street avengers) or a big 700 cfm carb.
which would i get more preformance out of with a 7000 rpm 327? i'm somewhat concerned with fuel ecconomy.. not that i'll be driving it to work, but the track is a good two hours drive away and i go almost every weekend.. (i'm out in the country) and i go to "the city" alot also.. and that's an hour drive....
i also want to take into account which is more problematic or harder to tune..
(side note: i was reading the "which is better for a 305" and the argument between the moderators really interested me since i keep putting down my friend's 355 TBI camaro.. althought the moderators went a bit overboard on it, i'd like to see more experiance on them)
(side note 2: i would REALLY like to know which would be better on a 327)
Old May 2, 2002 | 04:20 PM
NTChrist's Avatar
Good idea, Bird_of_Prey, maybe we'll get some useful, condensed info out of the moderators that are bent on killing each other with words...
BTW, I voted carb. Ease of set-up, and tunability were my two main reasons. If you're not experienced with GM ECMs, then tuning a PROM for a 327 (especially as they can rev higher, and can be slightly more "peaky" than most SBC's) can take months, if not years, of learning, burning, and tuning.
Old May 2, 2002 | 04:39 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I agree with the above.
Old May 2, 2002 | 05:00 PM
NJ SPEEDER's Avatar
i will agree with the ease opf set up for a carb, but i believe in teh long run tbi will be shown to make better power and get better mileage than a carb.
later
tim
Old May 2, 2002 | 08:10 PM
Car: Formula
Engine: 400 sbc
i'd go for carb too.. easier to tune alot more people around with experiance in carbs so if i got Q's.. i know i'll be able to find an answer somewhere..
and there's a good aftermarket for carburated engines..
'n that's where i lean to.
somebody make me lean the other way..
and years of prom burning is not appealing.
Old May 2, 2002 | 08:38 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
My vote goes carb. I wouldn't TBI anything that I wanted to make power out of. If you wanted it as a daily driver then maybe I would have said TBI where gas milage was the highest concern and performance secondary.
Much like some of the moderators, until I see someone actually post timeslips instead of "shoulds" and "I thinks" I won't take TBI serious.
Cleotiz
Jan 6, 2018 08:56 PM
Jynx88
Oct 4, 2015 08:19 PM
fulo
Carburetors
Jul 1, 2001 02:08 PM
fulo
Aftermarket Product Review
Jun 27, 2001 09:16 PM
Zio
Carburetors
Apr 30, 2001 04:47 PM
