350-305 geardrive
Old May 4, 2002 | 07:30 AM
jeff85iroc's Avatar
350-305 geardrive
Does anybody know if a 350 geardrive can be used in a 305 or
is there a seperate set for the 305.
Jeff
Old May 4, 2002 | 11:29 AM
Guest
Guest
Posts: n/a
Nice thing about a small block chevy, they all use the same timing set.
It'll work fine. Just make sure you get the correct one for your year (factory roller or not).
Old May 4, 2002 | 12:38 PM
iroc22's Avatar
I noticed you already have a Pete Jackson geardrive. You have to make sure you get the quiet one or it sends the knock sensor into fits; you probably already know this, just reminding you.
Old May 5, 2002 | 01:20 AM
jeff85iroc's Avatar
The geardrive in the corvette is a peter jackson and it is pretty loud i dont no why but i have had no problems with it at all.
and it's been in the car for 5 years.Again i dont no why i hav'nt (did i spell that ok) had any problems with it.
So a roller cam geardrive is different to a normal one.Do you no in what way.
Cheers
Jeff
Old May 5, 2002 | 01:24 AM
jeff85iroc's Avatar
Mine might be the quiet one but if it is i can't imagine what the loud one's sound like.
Jeff
Old May 5, 2002 | 01:08 PM
Guest
Guest
Posts: n/a
The cam gear on the factory roller setups is different. If you are using the factory roller cam and related hardware, you must use the right cam gear. I cant remember for some reason what the difference is.. heh. I am pretty sure theres a lip that sticks out of the back of it, and the thickness where the bolts are is less.
Old May 5, 2002 | 09:04 PM
iroc22's Avatar
It does have a little lip, but when I changed mine I thought there was an extra hole.
Old May 6, 2002 | 01:06 AM
jeff85iroc's Avatar
Thanks for that
I just would have gotten a normal drive.At least i know now that there is a difference between roller and normal.
Thanks again
Jeff
Harcourt
Sep 16, 2011 05:46 PM
Irockz
May 3, 2011 10:21 AM
ZAKS62
Nov 1, 2009 05:21 PM
Super_GTA
Sep 29, 2005 12:35 AM
