temp gauge..is it just me???
Old May 5, 2002 | 05:02 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
Hi all,when i changed my plugs,the temp. gauge quit working,i've checked it and seems loose,but last time i drove it,it seemed to work,today,the gauge worked for a while,then i looked down and the needle dropped down to the beginning,am i missing something on the connection???it just seems to slide on the sensor,it doesn't lock down or anything??still don't think i fixed the original fan problem either,is it just me...or am i missing something???
Old May 5, 2002 | 05:07 PM
Rage13's Avatar
Car: 89 Firebird
Same problem
I'm having the same problem with my temp gauge, it was working till i changed the thermostat. now it just zeros out when i turn the key.. i had the fan problem too, but i just wired it so the fan comes on when the key is turned
Old May 5, 2002 | 05:18 PM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
yeah i changed the thermostat also,still don't see how that's affecting the gauge
Old May 5, 2002 | 07:06 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
the sensor should just have a male blade connector on it and the connector on the wire is a female blade connector, if it's loose then squeeze the female part down a bit so it stays on. if it still doesnt work, touch the wire to the body of the car, the needle should peg at max because there is no resistance. if it doesn't then your gage is probably broken. if it does and gage wont work then your sender could be bad.
you can test it with an ohm meter. place one electrode on the sender's connector and ground the other near the sender somewhere. at 100deg F it should be about 1500ohms, at 260 i think about 55ohms
Old May 6, 2002 | 01:54 PM
Rage13's Avatar
Car: 89 Firebird
sensor
are you talking about the sensor on the water neck? i've heard others saying it on the block some where... i tested the gauge and it works fine, so its something between there and the motor
Old May 6, 2002 | 05:01 PM
Car: '87 Camaro LT
Engine: 355 L98
mine happens to be be in one of the heads. since your gage works then i'm assuming it's your sender that's bad. find out the resistance values it's supposed to read and check it or just buy a new one, mine was $7
Old May 7, 2002 | 04:30 PM
Rage13's Avatar
Car: 89 Firebird
I would but i don't even know where the thing is... you have any idea what color wire(s) would be going to it? and how do you get it if its on one of the heads?
Old May 7, 2002 | 04:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Temp gauge sender is between the #1 and #3 spark plugs. Fan switch is between the #6 and #8 spark plugs. Both of those have dark green wires. The ECM's temp sender is in the water outlet and has a yellow and a black wire.
Old May 7, 2002 | 06:48 PM
Rage13's Avatar
Car: 89 Firebird
do you need the ECM sender, and whats it do?
Old May 7, 2002 | 07:50 PM
Car: '87 Camaro LT
Engine: 355 L98
the ecm sender tells the computer what temp the engine is at, it uses the information to adjust fuel/air mixture
Old May 7, 2002 | 08:58 PM
Rage13's Avatar
Car: 89 Firebird
well that thing is coming out tomarrow...
and nice site Ukraine, sweet looking ride
but whats with the fire above the motor?
Old May 7, 2002 | 09:32 PM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
Thanx for all the info...
but this thing is just messing with my small brain,last 3 trips to town ,the gauge has been working,tonite in heavy traffic i watched as it crept up right past the 220 mark,then i noticed the gauges and the voltmeter kinda flickered,and watched the temp come down to the 220 mark,i thought,ALRIGHT fans came on,but can't get out of car to pop hood to check,so next light,up right past 220 again,same flicker and back to 220,once thru traffic came down to mid mark,@160??and stayed there until i got in driveway,then the temp gauge went to the bottom???it's just messing with me,weird stuff happen to ya'll too??????
Old May 9, 2002 | 01:17 PM
Car: '87 Camaro LT
Engine: 355 L98
rage, the fire is from the backfiring through the carb. at that point we had just put the distributor in and were setting timing, it was way off lol.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
