Harmonic Balancer no good??
Old May 5, 2002 | 06:59 PM
lenballz's Avatar
Hey guys I've got this rattle somewhere's at the front of the motor at idle and deacceleration in neutral( me under the hood using my hand to rev it up).. I thought it might be my power steering pump as the pulley is bent,, so I took the belt off and it still does it,,, now Im thinking maybe its the harmonic balancer?? do they make these rattles when they're shot?? I've got gear drive timing also.....
Old May 6, 2002 | 12:06 PM
Guest
Guest
Posts: n/a
Balancers make scraping noises when they are bad and they rub on the timing cover.
A rattle... its possible its the gear drive. I've heard of the Pete Jackson ones having the link bar come apart and make noise. What kind do you have?
Old May 6, 2002 | 12:26 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
When my balancer loosened up on me, it made all kinds of rattles knocks and grinds...make sure it is tight.
Old May 6, 2002 | 06:07 PM
lenballz's Avatar
Ok well as far as i know it is Pete Jackson gear timing,,, and I was just out having a closer listen with both belts off,, and there is also a scraping noise down there too,,,,, So i guess I"ll have to get up early and check both out! Thanks for the info guys,, I'll let ya know what the problem is when i find out
Old May 6, 2002 | 06:09 PM
lenballz's Avatar
Oh yeah,,,,, and would it be a good idea to start the car without the balancer for like 10 seconds so that way I can really narrow it down???? or is that a NO NO ????
Old May 6, 2002 | 10:08 PM
Guest
Guest
Posts: n/a
Shouldnt hurt anything. Might splash a little oil out of there, but should be otherwise ok.
The balancer if it slips, it usually heads towards the block and sometimes its easy to see that it has moved. It will also wobble when the engine is running.
italiano67
Dec 11, 2016 09:21 AM
LT1Formula
Nov 16, 2015 01:13 PM
InfinityShade
Aug 22, 2015 08:00 PM
theshackle
Aug 22, 2015 06:52 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
