Bad hesitation
Old May 5, 2002 | 07:44 PM
89BlackFBird's Avatar
Bad hesitation
Hey guys, This has been happening for some time, but its slowly getting worse. Basically all thats happening is that its hesitating when it accelerates. I checked the timing and its off pretty bad, but could that be it? Theres no vacuum leaks anywhere, Ive checked all the hoses that are visible. And what type of advance do I have in my car? Its a 89 v-6.
Old May 5, 2002 | 07:46 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If you're timing is off, it's going to make the car run like crap.
Old May 5, 2002 | 08:40 PM
Yeah but the timing gets wierd only when its at idle and its cold. When it warms up the timings fine.
Old May 5, 2002 | 08:45 PM
RJR99SS's Avatar
hesitation? wow....pretty broad topic there, could be many things.
i take it you're car is an auto though? quite a few things in an auto trans can cause a hesitation...
Old May 5, 2002 | 08:48 PM
no its a standard. It seems like a electrical problem to me. I checked the fuel lines and changed the filter. My fuel pump was changed last year and so was my O2 sensor. I checked all my plugs and wires along with my distributor. I do need to get a new rotor and cap though. Wheres the advance on the car though?
Old May 5, 2002 | 08:56 PM
Car: 99 Formula
Axle/Gears: 342
Do you mean idle, not timing?
Old May 6, 2002 | 12:14 AM
The Greek's Avatar
Car: 70 Nova SS
Transmission: TH350
I had the same problem on my car, it got narrowed down to an air or fuel problem. I changed the fuel filter and it was running fine.
Old May 6, 2002 | 02:28 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
what makes you think the timing is messed up?
Old May 6, 2002 | 02:32 PM
Car: 99 Formula
Axle/Gears: 342
I really think he's referring to the idle not timing. Cause he says it's fine when warm, but not cold.
Old May 6, 2002 | 02:41 PM
Engine: 406
yeah kinda short on the description
Old May 6, 2002 | 03:39 PM
breathment's Avatar
did ya check the voltage on the TPS?
Old May 6, 2002 | 04:00 PM
I checked the timing with a timing light. And both the idle and the timing are messed up. The timing goes wacky when its cold but when its warm its normal, or closer to normal. And when its idleing when its cold sometimes it will go down to 500 rpms and almost stall but then goes back up to normal. And also when its idleing it idles really rough untill it gets warm. But this whole thing only happens maybe half the time I drive it. Maybe a little more. Sometimes the car runs perfectly fine without hesitation or anything.
junior419
Apr 7, 2025 11:35 AM
69GTOby
Apr 18, 2016 02:34 PM
85 Jimmy
Sep 30, 2015 07:56 AM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
