Removing the AIR pipes and Smog Pump??????
Old May 6, 2002 | 11:02 AM
FLYNLOW92rs's Avatar
I was wondering if anybody had any information on removing these parts from a 1992 camaro RS with a stock 305 TBi? Please let me know, i hate those emissions equipment.
<p>
Are there any documented performence gains from this?
<p>
Old May 6, 2002 | 11:07 AM
TBI305Camaro's Avatar
RIP them out and throw them in the river and go to a hardware store and get some plugs to plug the holes in the air injection...also get that pipe from the cat off or youll blow all kinds of nasty stuff under the hood its real simple just take a look at the car and start pulling you shouldnt run into any problems
Old May 6, 2002 | 11:08 AM
your gonna need money for a new belt...no real perforamnce gain but definetly frees up some weight and gives you more room
Old May 6, 2002 | 12:10 PM
MiSFiT's Avatar
When i did mine the air pipes had holes in the and were all screwed up anyway so i just cut them off as near the manifold as i could and used a rachet to take the bottom parts off,make shure you plug the holes and plug them tight.............
Old May 6, 2002 | 05:57 PM
iroc22's Avatar
There's a article on the main site.
You will see maybe 2hp max because there's one less thing for the engine to drive. It also weighs about 5 pounds.
Old May 6, 2002 | 06:10 PM
87'IROC5.0's Avatar
You should try to save as much of the system as possible...just in case a few years down the line your state starts testing cars visually.
Old May 6, 2002 | 06:17 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I saved mine, but am glad I took that crap off, weights are in my sig
Old May 7, 2002 | 09:08 AM
I noticed the tech article but it shows a diagram of a TPI equipped car, anyone have a diagram of these parts on a 305 TBI????
<p>
Old May 7, 2002 | 12:12 PM
iroc22's Avatar
Same routing.
Use a 967K6 belt.
Old May 7, 2002 | 12:29 PM
i also got rid of my AC because it didnt hardly work so i had a much shorter belt and even less weight...if they start visually inspection under the hood id be screwed...i screwed every part of mine up so its trashed....i guess if i had to i could run dummy hoses and stuff
Old May 8, 2002 | 08:58 AM
Alright i got it all figured out now,
<p>
Thanks for all the help
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
transaero
Aug 31, 2015 01:14 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
