LG4 cam question
Old May 7, 2002 | 12:44 PM
v8transam's Avatar
Car: 1987 TransAm
LG4 cam question
Does anyone know if the an 87 LG4 has a hydraulic roller cam or just a hydraulic cam. Thanks.
Old May 7, 2002 | 01:41 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's supposed to be a roller, but I wouldn't bet on it... my late brother's 87 MC SS L69 was a flat....
The smart thing would be to look before you buy anything
Old May 7, 2002 | 02:12 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The 87 f-bodies all got roller cams. The Monte's L69 was an older, non-updated motor, so it kept the hydraulic cam, although there's a good chance that it had the bosses in the lifter valley for the keeper. The trucks had the newer block with the bosses, but didn't get roller cams until 96 I believe.
Old May 8, 2002 | 01:03 PM
Damon's Avatar
If it's got centerbolt valve covers it SHOULD be a roller cam motor, but that's definitely no guarantee. I've ripped into enough of them to know that GM was not shy about dropping flat-tappet cams/lifters into 87-up blocks. Particularly in low output applications- base engines/truck engines.
If it's got perimeter bolt heads it is definitely a flat tappet cam.
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Fronzizzle
Aug 9, 2015 01:15 PM
