running rough
Old May 8, 2002 | 06:23 PM
ray west's Avatar
running rough
when the car is cold it almost dies and if you give it gas it like sputters once its warmed up its fine its a 95 trans am with lt1
Old May 9, 2002 | 06:41 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
a little more info would be great...... setup?????
Old May 9, 2002 | 09:33 AM
Vader's Avatar
Ray,
Make sure the intake tract is sealed so that the MAF senses all incoming air. Check the 'O' ring seal under the MAP sensor (mounted to the top of the plenum on the right side). Clean the throttle body and IAC air passages. Check the temperature sensor resistance reading at a known temperature.
customblackbird
Aug 15, 2021 10:16 PM
jbd1969
Aug 17, 2015 07:06 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
