How much power gain with timing?
Car: 92 Camaro RS
Transmission: T5 manual
Dose anyone have an estimate on how much power can be gained by advancing the timing? I'm running a L03 and I'm just wondering if it worth the time, trouble and premium gas to advance the timing from it current stock position.
Thanks,
Thanks,
Car: 82 camaro SC
If your timing is already at it's optimum setting, you will loose power. It's not a matter of more timing will give you more power. It can in some case be worth a few HP if you play with the timing.
