stupid question, about vortec engines
I did a search for this, can't find anything. Does anybody know what year chevy started using the vortec heads on truck motors? Thanks for any replies.
Originally posted by Vader
Not to argue, but Mortec lists casting numbers for Vortec heads on '95 trucks. I also had an '88 1-ton GMC that had a roller cam - in a 350.
The roller cams weren't officially designated to the GM lineup in trucks until 1996. It was a freak maybe.
The official debut of the Vortec head was 1996. A good rule of thumb to remember this is in 1996 they switched from TBI to SFI, and that's when the new heads were used.
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
if roler cam started in the 90's how come I took apart a '87 T/A in the junkyard and it had a roller cam??? and it was a stock GM setup ??
Originally posted by vicV8rs91
vortec v6 = 94
vortec v6 = 94
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
vortec v6 = 94
vortec v6 = 94
Car: 88 ext.longbed 1/2 ton
Engine: TPI 350
Transmission: Slushbox 400
Hey 84 Z
The roller cam started in the TRUCKS in the 96's.
Hell my 87 truck block was roller cam ready, all I had to do was drill and tap the holes for the hold down spider.
Originally posted by iroc22
Vader,
Vader,
The old beater '88 had the roller cam block, but I can't honestly say I had the lifters out to look for roller tips and the spider. You're probably correct. As for the heads, the Mortec numbers list '95 casting dates, which would make sense for a '96 model year truck. You're right again.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
