Ticking noise
Old May 10, 2002 | 07:54 AM
85_ZED28's Avatar
Car: '85 Z28
Ticking noise
hey guys, I've got a ticking noise in the engine compartment, I'm pretty sure its the water pump, anyways how much should I expect to pay for a new aluminum one, and aslo, what would the weight savings be??
Thanks for any info
Old May 10, 2002 | 08:07 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You're lookin at about $90 or so. Are you sure it's the pump. Never heard of them making a noise. Could be a collapsed lifter or an exhaust leak, but then you shouldn't notice the noise by the water pump.
Old May 10, 2002 | 08:17 AM
NEOMASTERZ28's Avatar
Car: 85 z28
I also have a ticking noise and ijust got a new exuast put on i wonder can it be my new exuast but u only hear it when its in drive
85 z28
80 series flowmaster cat-back
jet air foil
tb coolant bypass
no air silensers
k&n
Old May 10, 2002 | 08:31 AM
89WS-6's Avatar
there shouldn't be that much of a weight savings with an aluminum water pump, just if it's more flow, than it will run cooler all together. More flow=more go!
Old May 10, 2002 | 10:30 PM
85_ZED28's Avatar
Car: '85 Z28
has anyone used an electric water pump?
Old May 10, 2002 | 11:36 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Plenty of people and they in addition to anyone else will tell you that they are definately race-only deals. the motor won't last very long on a daily driver.......
Old May 11, 2002 | 09:34 AM
ORAY777's Avatar
If you have a collapsed lifter how will your engine run?Will it run funny or have a lost of power?
Old May 11, 2002 | 10:34 AM
Car: 99 Formula
Axle/Gears: 342
The engine will lose some power, not sure how much, but it'll be drivable.
Electric water pumps are for racing applications only.
I'm working on finding an exhaust leak right now, it's pissin me off, I've checked the connections to the y-pipe and all seems tight, and that's where the noise sounds like it's coming from. Not too mention I suck at working on cars.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
