Some Important Things I Need To Know
Old May 10, 2002 | 07:52 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
what size is the stock 305 harmonic balancer on an 87 Z28?
cuz i need a timing pointer
also........what size bronze distributor gear do i need cuz i have a roller cam??
the distributor is an HEI with vacuum advance non-computer contolled
it has the coil in the center of the cap
just for my own knowledge...........do i need to measure the distributor gear i am replacing on the NEW distributor
or do i need the same size gear as the one on the old computer controlled distributor i am pulling out
:hail: NO COMPUTER CONTROLS
Old May 10, 2002 | 08:14 PM
boogie's Avatar
Coil in cap HEI distributors require a gear with a .491 shaft diameter and remote coil distributors require one with a .427 shaft diameter. You will not have to have a bronze gear with a hydraulic roller cam. GM #10456413 is a melonized gear for coil in cap HEI distributors that will work great.
Lonnie
Old May 11, 2002 | 05:53 PM
thanx
92GTA
Apr 9, 2016 07:39 AM
E_S
Aug 29, 2015 04:09 AM
Bob88GTA
Aug 18, 2015 03:31 PM
Ozz1967
Aug 16, 2015 10:23 PM
gta power
Aug 13, 2015 06:15 AM
