changing valve springs?
Old May 10, 2002 | 11:17 PM
Muzzs Ro's Avatar
I'm slowly picking up bits and pieces of knowledge on building engines, but with all newbies, I F'ed up. To make a long story short, how hard is it to change the valve springs on a pair of vortec's? or any head for that matter. I bought em stock, before I knew scroggins dickey had a pair of modded for sale. right now I'm limited to the XE268 cam, and I don't want to be dammit.
Muzz
Old May 11, 2002 | 12:05 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Are the heads on or off the car (assuming off) it's really easy. Either rent or buy the valve spring compressor tool that looks like a c-shaped vise grip or the kind that you clamp around the spring and screw it down to compress it. To get the old retainers out I think it's easier to get a long socket that almost as big as the top of the valve spring and hit it with a hammer. It might take a few hits as some of the retainers are bound to be gummed stuck to the top of the valve but the retainers will eventuall pop out. Take this time to replace intake and exhaust umbrellas and the o-ring on top of the valve. Then with the spring compressor over the newly placed valve spring compress it so you'll have room to slid the new retainers in and take the clamp off slowly. It might take a couple of valves to get the hang of it, but it's very simple.
customblackbird
Aug 15, 2021 10:16 PM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
