my car won't start!!!!
Old May 11, 2002 | 06:07 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I have a '89 IROC 350, automatic. I have had every starting problem possible: no cold start, no hot start, it will start and then it will hold an idle, then I turn it off it won't start again. The problem is between the key and the starter. When I turn my key I get no drain off the battery and the solenoids don't click, but i do get response in my temp guage and so forth. It used to not start, then I would simply wait awhile and it would start later. It has no pattern. any help would be greatly appreciated. oh, i do know that it is not the shifter or nuetral safety switch, i have manually flipped the gear indicater on the trans case to park.....thanks.
Old May 11, 2002 | 06:44 PM
SlowStangEater's Avatar
Re: my car won't start!!!!
I had the same problem a Week ago!!!! Remove your ground bolt from the engine block....clean it with a wire brush and clean that area of the block. Hook it back up and you should be good to go!
Old May 12, 2002 | 02:22 AM
2vmodular's Avatar
could be vats related too
Old May 12, 2002 | 05:15 PM
A very good possibility............Can someone post the VATS table for this guy???
Old May 13, 2002 | 09:13 AM
Poppa Chubby's Avatar
Car: Vert IROC Camaro
Engine: 355ci
Axle/Gears: 9-bolt w/3.45s
If there was a VATS problem would it just turn over and over?
I'm having a prob with my car not starting. She just won't fire up! Just turns over and over . . .
Old May 13, 2002 | 05:15 PM
Not Vats then..... Could be spark related or maybe your flywheel teeth and starter teeth are to worn down to make a connection. I really dont know for sure... Have you tried jumping it? It may be a drained battery? Make sure to check your connections also!
Old May 14, 2002 | 09:04 AM
Vader's Avatar
... i do know that it is not the shifter or nuetral safety switch, i have manually flipped the gear indicater on the trans case to park.....thanks.
Unfortunately, the neutral safety switch may not be located in the transmission. That was an old Chrysler TorqueFlite trick, but GM typically uses an external safety switch. Try looking at the shifter base in the console for the safety switch.
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
