will a CC HEI distributor work on a non CC engine?
Old May 12, 2002 | 11:43 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i ask this becuz i wasnt sure if there was anything i could do to mine so i could use it on the motor i wanna swap into my car........would there b a change....and if so.....could i do something to correct it?......thanks
Old May 13, 2002 | 04:36 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
no, it would not work, the computer controls the advance so the engine would not get any advance other than the inital you have to get a vacume advance distributar for your engine to run properally
Old May 13, 2002 | 08:02 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
It would work, but not properly, and throw things out of whack. Like said you have to get a vacuum advance dist.
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
midge54
Jan 29, 2017 07:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
stalkier
Aug 7, 2015 04:49 AM
