What is this white connector near oxygen sensor wire?
Old May 13, 2002 | 06:35 PM
cort351w's Avatar
There is a white electical connector at the end of the black plastic wire bundler (do those things have names?) that the oxygen sensor wire comes out of (they are in the same "wire bundler").
What does the white connector go to?
Note: This should be my last "Where do _____ go?" post for a while as I should be driving the car for the first time in 7 1/2 months tonight!!
Old May 13, 2002 | 06:38 PM
AlexJH's Avatar
Engine: 5.7L V8
Could it slide onto the temp sensor on the head? I think it might be what you're talking about.
Old May 14, 2002 | 12:04 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Brake proportioning valve connector?
Old May 14, 2002 | 01:43 AM
cort351w's Avatar
There isn't nearly enough wire outside of the "bundler" (see above post) for it to go all the way up to the cylinder head.
I'll check that out, but I'm not too optimistic. It's not a weather pack connector, it's box-shaped and tapers in width--sort of like a wide, fairly flat popsicle. I'm not completely sure that it was hooked up to anything, to tell the truth.
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
beast94
Aug 20, 2015 06:44 AM
stalkier
Aug 13, 2015 12:59 PM
92purpz28
Aug 11, 2015 02:30 PM
