hesitating
Old May 14, 2002 | 07:04 PM
86TATpi's Avatar
hesitating
I have a 1986 Trans Am w/ 5.0 TPI. I've noticed that when I hit the gas the car will hesitate then go. It also doesn't seem to have the power it did before. Any suggestions?
Old May 14, 2002 | 07:05 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Could be a couple things
replace the fuel filter lately??
still have the stock cat?? if so let the car warm up at nite, if the cat is glowing it's clogged.
Old May 14, 2002 | 07:12 PM
86TATpi's Avatar
I replaced the fuel filter last year. It still has the cat, so I'll check that tonight and post an update.
Old May 14, 2002 | 08:05 PM
SkyWarrior's Avatar
Car: 1986 Pontiac Trans Am
Engine: 305 LG4
Transmission: Borg Warner 5 Speed
I have the same problem with mine. My cat is only a year or two old and I've changed my fuel filter about a million times. One guy said it may be my O2 sensor, so I'm gonna try that.
Old May 15, 2002 | 08:39 AM
Vader's Avatar
86TA,
Since you're running a TPI, check the TPS voltage and make sure the IAC is whistle clean. And since you have an '86, check into the upgraded GM PROM for you ECM that addresses some of the problems you might be having. It made a pretty noticable difference in my '86.
Old May 15, 2002 | 08:41 AM
Vader's Avatar
SW,
Your problem isn't likely the same, since you are using an E4ME carb. Check the M/C solenoid, and the accelerator pump operation. Lean problems at throttle tip-in are very easy to solve on a carb with a few adjustments and cleaning.
Old May 15, 2002 | 01:25 PM
SkyWarrior's Avatar
Engine: 305 LG4
Vader,
So you don't think it'smy O2 sensor? I haven't changed it for atleast 100,000 mi. My mcs clicks like it's supposed to, but I don't know how to check my accelerator pump. Hell I don't even know what it is!
Old May 16, 2002 | 06:39 AM
86TATpi's Avatar
I'm going to wait for the weekend to check everything for sure. But it will run rough and hesitate when it's been sitting for a while. After it warms up, it runs fine. Any suggestions?
Old May 16, 2002 | 11:41 AM
gtabadboy's Avatar
Check your fuel pressure if it is too high then car will hesitate. Also your timing should be advanced about 10 degrees and check your TPS voltage, especially at WOT (you dont need to run the car, just turn the key and open the throttle the whole way and see the voltage).
Fanatic1074
Oct 3, 2022 05:57 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
