Gas tank filler neck
Old May 15, 2002 | 08:11 AM
Buck268's Avatar
well, I am leaking gas outta my car tanks filler neck. I looked at it, and it seems like the little metal door that automatically closes when you remove the gas nozzle is bent up. Not a lot, just a very small amount - enough fer gas to leak out with 3/4 or more, hitting corners. How fixable does this sound - pease tell kme i dont need to drop the tank!!
Old May 15, 2002 | 09:31 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
just do like adam sandler did on what the hell happened to me cd and use a freakin rag for a gas cap there used to be alot of muscle cars way back when that used to do this alot or so my dad says. i wouldnt know but he would he lived way back then
Old May 15, 2002 | 11:53 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
As far as I've seen, that little door is to prevent large items from falling in the tank, and, to only allow an unleaded gas nozzle inside. (Leaded nozzles are wider.) If you're getting gas leaking onto your car on a tight turn, you might want to replace your gas cap, the seal is probably bad. OR, the boneheads at the gas station aren't tightening your cap enough.
(In NJ, we have those full service stations; no self-serve. I always remove my own cap and put the cap back on myself- seems the morons that pump my gas are too weak to tighten the cap until it clicks.)
Old May 15, 2002 | 11:57 AM
RJR99SS's Avatar
heh, we have the opposite problem in ohio. The idiots at the gas station always rip the fuel door off my cars, one even striped the gas cap threads.....i didnt think that was possible.
Thats why i dont use full service anymore, and if i do i always tell them "ok, you think you can handle opening the door gently?". They give me dirty looks, but they dont break anything anymore.
Old May 15, 2002 | 07:07 PM
Buck268's Avatar
oh, my mistake! thats a relief! Its *should* be the cap then... would any cap off of a 82-92 f-body work then? Just go to a junk yard...
Old May 15, 2002 | 07:13 PM
camaro6spd's Avatar
yup
Old May 15, 2002 | 07:14 PM
Buck268's Avatar
woohoo! :lala:
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Bohemian
Aug 15, 2017 05:11 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
