Front turn signal bulb burnt out
Old May 15, 2002 | 08:01 PM
85_ZED28's Avatar
Car: '85 Z28
What is the easiest way to change this bulb, do you have to take the light assembaly off??
(sorry if its a dumb question )
Old May 15, 2002 | 08:08 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I'm pretty sure you can reach up from underneath. I can't remember though, and mine is an 84, which I can't remember if it is the same as the newer stuff or not!
Old May 15, 2002 | 09:19 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Just go to the store and get some blinker fluid.
Old May 15, 2002 | 09:20 PM
JP84Z430HP's Avatar
Car: 84 Z28
Don't forget a new muffler bearing while you're at it!
I can just see this thread getting closed, now!
Old May 15, 2002 | 09:27 PM
idrag2's Avatar
LMAO, you think he might need a left handed ball ping hammer?
U should beable to get to it from under the car
Old May 16, 2002 | 07:42 AM
85_ZED28's Avatar
Car: '85 Z28
I can't get it from under the car without taking off the assembaly
thanks for the sarcasm, jeez
Old May 16, 2002 | 07:59 AM
MD83Z's Avatar
You should be able to reach up from underneath (back a little) and twist the bulb socket out of the blinker housing.
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
