Radiator ?'s
Car: 92 Formula
Transmission: A4
Radiator ?'s
It looks like I figured out my problem...
Using a cooling system compression testor, I discovered a crack in my radiator in the upper right side... so I need to buy a new one.
I think that I am going to Autozone to get it, but here is my question:
What is the difference between the "Plastic & Aluminum (1-row)" and the "Metal (3-row)" radiators? Besides the obvious compositions... Which one should I get for the bird?
Car: 91 z28
Engine: 305 tpi
i just put a 3 row one on my camaro and i noticed that it runs cooler and heats up faster.i only paid 130 bucks for it shipped to my door
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i don't know how much a stock replacement costs but i put a Griffin in my car for about $190.00
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Get the aluminum one with the plastic tanks just like the stock one. I tried both the copper brass one with the three rows and the aluminum one that looks like stock. The aluminum one kept the car about 10/15* cooler, I had the 400 in the car at the time also.
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
I did the same as Wayne...mine cost 35 with the shroud at a u-pullit, Go tit out of a firebird and it works great Ive yet to see 200* Find one still holding coolant.....
Originally posted by Mark A Shields
I would definately get a 3 row radiator, which will have increased surface area creating better cooling.
Car: 99 Formula
Axle/Gears: 342
Originally posted by Bralgar
Actually there is a reason GM switched to the single wide row aluminum radiators. Heat being displaced across a wider plane with increased vane area cools better. I read a tech article on it somewhere, I can't really remember all the specifics. But believe me, or not, the single wide vains have more cooling area than the 3 row. But old schoolers will jump in to dispute the claim.
