cooling system
Old May 20, 2002 | 08:52 PM
Hung Start67's Avatar
cooling system
Ok need your help guys...my 92 z is acting up..lol...ok..wife went to barnes and noble to buy me a new penthouse magazine...lol..yeah right...ok..she went to buy a book on cooking yeah thats better...ok..car overheated badly...i was at work and got the call...rescue time...lol..ok..picked up a 180 deg thermostat and installed...still had the orig 195 in place...well car ran much cooler..turned a/c on and drivers side fan kicked on..correct no? ok..let car sit there and idle...a/c off...well the temp got to about 235-245..and not one fan kicked on...a/c back on..drivers side fan came back on thank ***..lol...ok question...is the fan switch bad...relay?sensor bad? is there a cooler switch i can buy from somewhere so the fan kicks on earlier? any ideas would be helpful..thanks guy....gary.
Old May 20, 2002 | 08:55 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Not sure how to fix the fans, but a 180* stat won't do much good without a lower fan temp rating. The fans don't come on till about 220* stock.
Old May 20, 2002 | 09:35 PM
CobraKiller's Avatar
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
do what I did when i was having that problem. Wire up a nice little switch directly under your dash on drivers side and run the fan all the time. No problems with cooling anymore for me.
Old May 20, 2002 | 10:03 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: cooling system
Hey man sounds like the fan switch to me. You could always splice your wire going into the switch and make yourself a fan switch.
Hey Cobrakiller, wouldn't having the fan on all the time eat up some HP?
Old May 21, 2002 | 12:49 AM
Morley's Avatar
Re: Re: cooling system
ummm...how? The fans are electric.
~M~
Old May 21, 2002 | 09:00 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Extra drain on the alternator, perhaps. What, did you think that electricity was free?
One thing you'll learn if you study Physics--there really IS no such thing as a free lunch.
Old May 21, 2002 | 09:02 AM
I don't have to leave them on all the time. I have a switch but I do leave them on quite a bit.
Old May 21, 2002 | 11:36 AM
Morley's Avatar
The drain on the electrical system from the fan is almost imperceptable. The alternator is spinning and making electricity all the time, so in essence it is "free".
~M~
Old May 21, 2002 | 11:39 AM
99Hawk120's Avatar
Nope, try again. There is extra drag on the motor from the alternator being required to meet the extra load. The alternator is producing power all the time, yes, but the amount is controlled by the internal regulator which varies current output based on the "sense" wire.
It's been proven that DRL's lower fuel mileage--how do you think that happens? And many of them pull less current than one of our fan motors. Just because you can't perceive it doesn't mean it's not there.
Old May 21, 2002 | 03:19 PM
Hypertech to the rescue!!
Ok guys ordered myself a Thermo-master chip,a cooling fan switch and 160 deg thermostat from hypertech this morning..that should take care of the cooling problem...plus maybe give the car a little more grunt...anyone out there with a 350 z using the thermo-master? any diff in the seat of pants? just curious...later guys will tell you how it feels...hope it does the trick..gary
Old May 21, 2002 | 10:59 PM
I've run the thermomaster chip in the past. You'll like the improvements in the butt dyno.
Old May 22, 2002 | 12:12 AM
Car: 1988 IROC-Z
Engine: 427 SBC
What does a Thermo-master chip do exactly?
Old May 22, 2002 | 01:05 AM
Morley's Avatar
So by that logic, the 6 halogen lights on the front of my car lower my gas mileage, cause they pull way more juice than my fan does. Sorry, not buying. I have owned this camaro too long and driven her too many miles to even begin to buy that one. My daytime and nighttime gas mileage are no different.
~M~
Old May 22, 2002 | 08:14 AM
99Hawk120's Avatar
Suit yourself.
Old May 22, 2002 | 09:15 AM
Advances ignition timing,firms up the shifts,improves fuel economy,improved throttle response and turns the fans on earlier. And it has to be used with a 160* stat.
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
64goatman
Sep 9, 2015 01:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
