First time at Track, need psi info
Old May 22, 2002 | 01:37 PM
91_350TPI's Avatar
Car: Lucky Dog Racing 1992 Chevrolet Camaro Z-28
Engine: 379 cid Chevrolet race engine
Transmission: Coam TH-350 w/ transbrake
hey guys. I'm going to the track for the first time tonight and was wondering what kind of tire pressure you guys run. I have 245 50's on it right now with all the free mods. Right now leaving at an idle I have to roll very slowly into the throttle and am stil spinning through first gear (5000 RPM). However; thats on the street with 35 psi all the way around. Thanks in advance. Drive on..............Damien
Old May 22, 2002 | 02:07 PM
Guest
Guest
Posts: n/a
It varies depending on the tire/rim combo. You'll just have to experiment.
I found that (on a different app) the tire worked best when inflated to the max pressure (44psi). It was the correct width rim for the tire too. Just so happens thats what it liked.
I'm sure you can do some experimenting close to home.
Old May 22, 2002 | 02:59 PM
91_350TPI's Avatar
burnout or not?
Old May 22, 2002 | 03:57 PM
Guest
Guest
Posts: n/a
Street tires? Not unless you like making a smoke show and wasting rubber. I usually give a quick spin to throw the rocks off if the track is a dirty one.
If you can, definitely drive around the water box. Some tracks for reasons unknown to me wont let you do that though.
Old May 22, 2002 | 06:05 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I found maxing the front out (45psi) to lessen rolling resistance and about 26psi in the rear of my Firestone SZ50's worked best.
But it's really about testing and tuning at the track.
Old May 22, 2002 | 06:38 PM
Morepower383's Avatar
I do a lot of street racing with my car and run a Mcreary tire- TRUE RADIAL TIRE- @10psi and it works ...You just gotta know your car....EVEN THOUGH it's a radial try bringing it down to like 15psi and see if it makes a difference....It should, but it really depends on the car, like how heavy it is and how much power you have and also put your front tires to 40psi.
Old May 22, 2002 | 11:36 PM
91_350TPI's Avatar
Thanks for the info guys. Tonight I pumped the front to 45 psi and left the back at 35psi. I was going to change it from 35 - 20 after the first time run but since I got there so late I only got 2 time runs and didn't want to change anything. The car was not as quick as I expected it to be but I had a hard time keeping it hooked. best run was 2.042 60' 9.336 75.21 660' and 14.654 93.87 1/4 mile. 60' was what I thought it would be but wasn't making enough HP on the big end. Other runs were around 2.15-2.18 60' and a 2.287 burnout. I was pretty inconsistent but I did manage to go 3 rounds before going .496 red
Do these 60's and 1/4 mile ET's sound about right or am I way off? Thanks again. Drive on....................Damien
specialized
Jun 18, 2022 09:26 AM
fasteddi
Sep 2, 2015 10:29 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
