Error in TFS heads?
Old May 22, 2002 | 03:47 PM
BenDoe91z28's Avatar
Error in TFS heads?
Hey guys, i got my trick flow 23* aluminum heads today and i noticed something wrong i think, but i'm not sure if its normal. They drilled the stud holes to deep i think and hit the intake port. Whel the stud is in, it doesn't poke out the bottom though. Can somebody tell me if this is normal? Has anybody else had this problem, should I call and get a different set? Should i call TFS and complain?
you can see it on the lower port.
Old May 22, 2002 | 04:19 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i heard tf heads were crap,
Old May 22, 2002 | 05:10 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Mine are like that too. I dont think its a big deal, there are other heads that have the same thing I think.
Old May 22, 2002 | 07:35 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
same thing....
Old May 22, 2002 | 08:00 PM
wataru's Avatar
I would'nt go so far as to call them crap. I think they flow alright for a "budget" head and the castings are'nt to bad either. They get the job done IMO.
Old May 22, 2002 | 09:18 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Studs
Be sure you put sealer on those puppies cuz they will leak oil if you don't. (into the cylinders)
Old May 22, 2002 | 10:24 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Yeah, mine are like that too. It isn't a huge deal.... just do like mentioned above and use some liquid teflon on the threads of the studs to ensure no oil consumption through those holes. I also can't name names, but I know I have seen this on other heads.
From Wasp:
Toolsin
Feb 2, 2016 06:55 AM
92projectcamaro
Jan 18, 2016 08:00 AM
z28guy134
Sep 1, 2015 11:50 PM
two-if-by-sea
Aug 31, 2015 06:30 PM
