84 gas in oil
Old May 22, 2002 | 09:18 PM
88Camaro88's Avatar
84 gas in oil
I garaged my 84 camaro for the winter and tried to start it up afew times it would start and run wicked rich.. Then it wouldnt start so i cut the cat and it began to start again... And run really rich. Recently it was 90 and i started it and it idling strong at 800 and was running rich... Anyways... I checked my oil and there is gas in it.. Anyone know what can be causing this.
Old May 22, 2002 | 09:33 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
my 83 did the same thing. The oil was extremely thin because of all the gas. It smelled like gas horible. anyway I did a carb rebuild(set the mixture screws to 2 and 1/2 turns out)and changed the oil. and bam....problem solved. It still didnt run quite right for awhile..besides the fuel problem.. after all it was stored for 2 years. Oh yeah.. I had a flooding problem. there was junk between the needle and seat. from sediments in the fuel.......
its either a misadjusted carb that needs adjustment or rebuild
Rob...
P.S due to the gas thinned oil you might see some blue smoke. That should go away when you change the oil.
Old May 22, 2002 | 09:34 PM
Car: 1983 Z28 Clone
Transmission: TH350
oh yeah, of coarse theres always the good 'ole stuck choke..
Old May 22, 2002 | 11:44 PM
boogie's Avatar
Another possibility is a bad fuel pump.
Lonnie
Old May 23, 2002 | 07:09 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
another is blow-by
Old May 23, 2002 | 09:50 AM
camaro6spd's Avatar
he has TBI....this post belongs in the TBI Forum....the Tech/Gen forum is cluttered up with people just posting here b/c everyone looks here....maybe if you guys started posting in the right boards then they would be visited more.
Old May 23, 2002 | 10:11 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
He has TBI on the '84? No kidding!
Change the oil soon... I hear that bearings dont' like gas...
Old May 23, 2002 | 01:11 PM
camaro6spd's Avatar
umm...he said that he had it...that is what is in his sig....go look.
Old May 23, 2002 | 01:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
His sig mentiones an '88 with TBI, but he was asking about an '84 that was garaged...
Unless he made a typo when he put '84... but I'm guessing they're two different Camaros!
Old May 23, 2002 | 06:30 PM
88Camaro88's Avatar
I have an 88 i drive now and my 84 is garaged which has a carb
Old May 23, 2002 | 07:41 PM
Engine: 406
glad we cleared that up....
Old May 23, 2002 | 07:43 PM
Car: 1983 Z28 Clone
Transmission: TH350
:lala:
1992 Trans Am
May 10, 2023 07:19 PM
Derick15
Sep 17, 2016 05:28 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
