Smog pump removed Help!!!!
Old May 25, 2002 | 11:35 PM
quiksilver1j's Avatar
Today i removed all of my smog pump stuff but i don't know what the plug the stock headers with until i get aftermarket ones. I tried to go NAPA to find a bolt to put it there and by following their chats its a 14mm 1.5 thread but they don't have it !!! so i went every where and cant find anything with those deminsions what should i do. i don't really wanna break those air railings cause i might need them in the future. any responce would be appciated!!
Old May 26, 2002 | 12:08 AM
Joshua Leslie's Avatar
what I would do(and keep in mind I am the ultimate hack) would be to fill the holes with some muffler mender(bondo for the exaust)
then, if you need the holes open again, just drill it out!
Old May 26, 2002 | 12:59 AM
TBI305Camaro's Avatar
i went to a little crappy hardware place with one of the air injection screwins (technical term) and i found a plumbing plug that worked perfectly.
Old May 26, 2002 | 01:21 AM
Slo86TA's Avatar
go to Home Depot and get part #: A-737. It's a 1/4" square head plug made by Watts AB. I believe it's in the plumbing/soldering section. they're $1.00 each.
Old May 26, 2002 | 07:10 PM
i don't think 1/4 inch will fit will it? i believe that threads are metric, i have an 87 what year is urs
Old May 26, 2002 | 08:41 PM
Slo86TA's Avatar
mine is a 86.. they should be the same. the info I read was off a spare for just in case I didn't tighten one good enough and the plug comes out. I forgot where I got the ones that I used a 82 TA that i sold a few months ago but those had an alan head instead of the square head.
Old May 27, 2002 | 12:49 PM
mckenzie's Avatar
not sure of the size plug, but it is a pipe thread...go to your local hardware store!!!!!!!!!!!!!
Old May 27, 2002 | 06:21 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I used 1/4 inch allen plugs. .50 cents each from NAPA.
They actually aren't the exact size but you're not going to hurt the exman. I torqued mine down and have no leaks.
Old May 29, 2002 | 09:23 AM
everything worked out with the plugs , but any suggestions on getting that bolt off the head that holds the air tubes in place
thanks for your help
Old May 30, 2002 | 11:06 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
If you're talking about the one on the rear of the pass head it should come off easily with a wrench. At least mine did.
Old May 30, 2002 | 12:12 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Go to the hardware store and look and the brass plumbing connections. For sure they will have something that will work there.
RazorN8
Jan 7, 2022 11:44 AM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
