Installed new brake pads, now they screech, what gives???
Old Jun 4, 2002 | 05:53 PM
1BadGTA's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 Liter
I just replaced my original brake pads with Raybestos Brutestops. They are quality brakes (semi-metallic) but I didn't think they would screech like they are. I was told that because they are quality pads, they will screech a little. Is this a temporary thing? Will they "break-in", then stop screeching? It only happens sometimes when I apply a little pressure, then when the pedal is fully pressed it stops. It's embarrassing though because it sounds like they need to be changed.
Thanks.
Old Jun 4, 2002 | 06:30 PM
Hulk0202's Avatar
Give them some time to bed, then start worrying about it. Many times it will stop, but.......
Old Jun 4, 2002 | 06:33 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Metalic=screeech!!!!! My wifes car sounds like a d**n bus.
Old Jun 4, 2002 | 08:15 PM
RJR99SS's Avatar
did you remember to install the metal mounting clips on the pads?
Thats the number one cause for brake squeeling...
Old Jun 4, 2002 | 08:36 PM
82camaro's Avatar
Car: 82 camaro SC
Did you tweak the mounting clips so the pads fit real tight? Did you use any anti-squeal goop?
Old Jun 4, 2002 | 09:42 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
You oughta hear the brakes on the box truck at work.
They sound like a high pitched squeal.
I'm told by my shop foreman that the truck has done it since it was new.
I've got my own question about brakes.
I had to replace rotors and pads on my Plymouth Acclaim (my daily driver)
My pedal is still spongy after putting about 30 miles on the car in the past 24 hours.
The fluid is full in the reservoir, and all air to my knowledge is purged from the system.
I'm told that the air will gradually work itself out of the system.
All I know is that I'm pissed because my pedal is much less sensitive now. I don't like it
Any ideas?
Old Jun 5, 2002 | 06:19 AM
Engine: 406
If you have all the air bled out properly..you shouldnt have the sponge effect..they will not work themselves out....unless you have a leaky system...wich would not be good...I would try bleeding them again...dont let the resevoir get empty oe low while you are doing this...If your problem persist..take a look at the master cylinder....Anytime someone tells me.."it will work itself out" I bust out the flag......Wish my car could fix itself, save me some fishing time...
Old Jun 8, 2002 | 08:30 PM
1BadGTA's Avatar
Engine: 5.7 Liter
Are semi-metallic the best brakes to buy? Aren't most brakes semi-metallic? Are the GM brakes semi-metallic? The squeal is horrible. Someone told me to hit the brakes hard a few times so the brakes will mate better with the rotors. True??
Old Jun 9, 2002 | 12:05 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
After you intalled them, did you go out and really give them hell to make sure that everything was cool like a lot of people do? Cause if you heat up new pads too much, they will glaze (harden), and they won't shut up for the life of the pad.
Old Jun 9, 2002 | 01:28 AM
RJR99SS's Avatar
well they'll only glaze if they're cheap, bonded pads. If you got the riveted ones, then i wouldnt worry about that.
yes, most automotive brake pads are semi-metalic, the ones gm put on there were semi-metalic too. But the material of the pad isnt the problem.
question, did you have your rotors turned?
Old Jun 9, 2002 | 08:56 AM
Engine: 406
you can buy non metalic...thats what I did for my wifes Olds...after the switch,,,no more screech....they just dont last as long..but they are also cheaper...metalic brakes will screech, sometimes...fact...you could always try some brake cleaner.
Old Jun 9, 2002 | 07:18 PM
1BadGTA's Avatar
Engine: 5.7 Liter
I didn't have the rotors turned. The car only has 38k miles on it. I didn't think it was necessary. What I'm looking to find out is if the screeching will stop with time. Since the pad change-out, I've put about 100-125 miles on the car.
Old Jun 10, 2002 | 05:54 AM
Engine: 406
Might get worse with time....and dust and brake dust..try the brake cleaner..
weather or not they need turned depends on how bad you let the first set get...ive seen a rotor melted on a car with 20,000 before...
Old Jun 10, 2002 | 10:33 AM
DSaylor's Avatar
When the brakes started squeeking on my astro, and the pads and rotors still looked good, my brothers auto shop teacher said to put a couple lines of valve grinding compound on the rotors.
Stopped the squeek, and the pads aren't wearing out any quicker than they should. Now whenever I do brakes, I always use a little, even on new rotors, and I haven't had any problems since with glazing or squeeling.
Put about 3 or 4 stripes across each side of the rotor, I'm hitting 100% using this method so far.
Old Jun 10, 2002 | 12:30 PM
Vader's Avatar
Carbon-metallics don't squeal readily, but they certainly do produce dusting.
Ceramics may tend to squeal just a bit more than carbo-mets, but don't dust nearly as badly.
With any pad replacement, its always a good idea to at least break the glaze on the rotors to help bed in the shoes and inhibit glazing/noise. The lapping compound trick is a good one. I might have to try that.
Robt TG,
If you have a soft pedal with 4-wheel discs, it's either due to air in the lines, a caliper that is sticking on the bracket or cracked, or brake hoses that are swelling under pressure. If you're positive all the air is out and the calipers are in good condition, you might need to switch to better than stock brake hoses. OEMs sometimes use steel rings crimped around the hose to minimize the balooning effect, and those can rust away. Stainless braid-covered lines prevent this, but tend to have their own particular problems in exchange. Nylon composite (layered) hoses tend to eliminate both sets of problems, but they aren't as "pretty" as the stainless braids. Personally, I'd rather have better brakes than pretty hoses.
If you have rear drums, you could also have brake hardwar sticking or a cracked drum, allowing it to flex and expand.
Old Jun 10, 2002 | 08:22 PM
1BadGTA's Avatar
Engine: 5.7 Liter
Sucks when you replace your brake pads and they sound worse than the ones you replaced them with. Which didn't make any noise, they were just wearing too thin. Guess I should have resurfaced those rotors after all....
Old Jun 11, 2002 | 09:01 AM
Vader's Avatar
The good thing is that you can probably still do it and use the new pads.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
kyleb24
Aug 15, 2015 08:24 AM
Zachattack0925
Aug 12, 2015 09:52 PM
