Can I rip this crap out?
Old Jun 5, 2002 | 07:55 AM
FatOne's Avatar
85 Z28 with new 350 carb setup. Had 305 with TPI. I've already taken off the A/c stuff now wondering about cruise control? Also the vapior can. From what I can tell its not hooked up to anything. What is that round ball under the car on drivers side?Looks like something for the cruise? Can this be taken out also? Just trying to clean up engine compartment a little. Anything else that I would not need?
Old Jun 5, 2002 | 08:28 AM
snakeskinner's Avatar
cruise can all come out. Canister/evap equipment can come out but is illegal for emissions reasons. "ball" is vacuum source tank that helps accessories like a/c, cruise, etc. Sounds like you don't need it anymore though.
Old Jun 5, 2002 | 01:26 PM
FatOne's Avatar
Hay thanks. With emissions I wont have to worry I think. Still have the old smog pump and lines. If nothing is going to the damn can then why have it in there? If I need I'll put it back. Then I'll be taking off old headers. Replace with new Hookers. No ****y tubes to get in the way.
Old Jun 5, 2002 | 02:22 PM
sa85z's Avatar
vapor can
Nothing from the smog pump goes to the can. There is a line from the the fuel tank, to vent, and one from the can to the carb/tpi to help burn off some fumes. If the car is running then the carb/tpi end is plugged. You may want to check to see what they did with the tank vent line. Don't think you'd want fumes under the passenger area of the car. Best suggestion I've seen, and did on a Chevy P/U was put a $.99 inline filter at the end of the line with another piece of hose to the most forward underneath point, away from heat.
Veaceonee
Sep 29, 2016 08:15 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
dbrochard
Sep 28, 2015 07:40 PM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
gta892000
Sep 16, 2015 12:37 AM
