Will a double roller timing chain set off knock sensor ?
Old Jun 5, 2002 | 11:02 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Engine: Forged 350 with D-1SC
I am hearing rumors that a double roller timing chain will set off a knock sensor.
Also some people say the same for the quiet gear drives (not to change the subject).
But others say these are false acuisations.
So what is the truth?
Thanks.
Old Jun 6, 2002 | 03:44 AM
Morley's Avatar
No, double rollers aren't any noiser than the stock set, quieter if anything. The gear drives (quiet ones) do make a bit more noise than a chain but everyone I've takled to said it hasen't affected their knock sensor. The knock sensor is actually listening for noise in a specific frequency range, the range that detonitation "vibrates" in.
~M~
Old Jun 6, 2002 | 08:50 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm using a double roller, no problem.
I've heard solid lifters will cause the KS grief.
Old Jun 6, 2002 | 09:20 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Double roller shouldn't cause any troubles.
Been running them for years in mine.
-Rich-
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Andrew6.688
Dec 13, 2015 10:59 AM
camaro71633
Sep 1, 2015 10:24 AM
MY87LT
Aug 17, 2015 08:43 AM
