Throttle Cable Sticking!!
Old Jun 7, 2002 | 10:18 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
I noticed that my idle was kind of high after I would come to light, and that I had to push the brakes down alittle harder than usual. Well the other night I was checking out my new exhaust gasket, to make sure it wasn't leaking and was reving my motor, and notice that my Throttle Cable was sticking, What kind I do to fix this?
Old Jun 7, 2002 | 10:26 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd check the condition of the spring. Happened to me once WOT and it was stuck, talk about scary.
Old Jun 8, 2002 | 11:30 AM
Vader's Avatar
If the cable is hanging in the housing, don't even mess with it - just replace it. It won't get better by itself, and will only get worse until you end up "freeing-up" your cable inside the rear end of a truck or brick wall.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Randomtask2
Sep 7, 2015 05:06 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
