a little blue smoke
Old Jun 9, 2002 | 04:14 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
a little blue smoke
Noticed a little blue smoke on start up the other day. What is the cause of this and should I be concerned about it??
Old Jun 9, 2002 | 04:25 PM
rezinn's Avatar
The valve seals in your heads are worn, so they leak a bit of oil that has accumulated on them into the combustion chamber while your car sits. Unless it gets really bad there is no reason to worry.
If it's more than "a little bit," and you see it when you shift, be worried about your piston rings.
Old Jun 9, 2002 | 06:11 PM
azvolfan's Avatar
At the moment it is only at start up. The car only has 60,000 miles on it. So hopefully it won't get any worse.
Old Jun 9, 2002 | 08:26 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
My car has 63,000 and does it. It will progressively get worse and will get worse faster if you drive hard. Nothing to worry about though unless you are losing a lot of oil. Just a Chevy thing.
Old Jun 9, 2002 | 08:46 PM
BenDoe91z28's Avatar
my car looses 1.5 quarts of oil per tank of gas.... he he he consider "a little blue smoke" a blessing
Old Jun 9, 2002 | 08:49 PM
Marin's Avatar
I was upset about it earlier, but apparently it happens on chevy small block that have over about 50000 miles, becaues the valve stems are not of the best quality. The new ones are something like $15, but it's not worth replacing just them, I guess you should probably do that when (if) you install something else, like new heads...
And try using more viscous oil, don't use synthetic anymore or try getting one of those oils for older engines (i'm trying Valvoline Maxlife 5W-30)
Old Jun 10, 2002 | 02:21 PM
jrl9873's Avatar
I've had the Puff O' Blue ever since I got the car with 115K miles on it 5 years ago. She's up to 127K now, with no considerable change in the Blue. Doesn't seem to eat up a noticible amount of oil either. Maybe I'm just lucky...
Old Jun 10, 2002 | 04:13 PM
pauls's Avatar
Mines a 85 305 TPI, 50,000. Bought it from orig owner at 45,000. Has had 'smokey startup" for years he told me. Still does. I even switched from regular Vavoline , which I've swore by for YEARS, to Vavoline Max Life, hoping it would help reduce problem / soften seals. No way. However, I change oil every 3,000, and notice no real reduction in level on the dipstick, either. In other words, that embarassing belch of blue smoke must not be burning as much oil as it would appear to be. Small blocks of this era are famous for poor valve seals. You'd think by this stage of the game, G.M. would have known better than to try to save 50 cents/ unit, or whatever the savings probably was. They obliviously knew better. It somewhat ruins the otherwise fine appearance of a sharp car, if you know what I mean. Still goes like h*ll ,though!
Old Jun 10, 2002 | 06:43 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
i agree with pauls that it ruins the apperance but mine does it to. i really don't care but it is kinda of embarrassing. but its really nothing to worry about.
Old Jun 10, 2002 | 08:11 PM
labrat's Avatar
Car: 87 IROC-Z
Transmission: automatic
Both my 85 Z-28, 41,000 (sold) and my 87 Iroc 40,000 do the smoke thing, so both age and mileage play a factor. I put 5-30 Mobile 1 synth oil in the Iroc and it really has helped the smoke problem. It's not nearly as bad.
Old Jun 11, 2002 | 09:33 PM
pauls's Avatar
The fact that synthetic helps reduce smokey start-up is good to hear. However, I've also read on this sight elsewhere that synthetic can sometimes worsen the problem ,and /or encougage leaks due to the fact that it flows better and can actually loosen up debris in the engine that may actually be "blocking" or "sealing" up stuff. Would anyone else care to comment on this? This seems to be a very relevant topic for alot of 3rd gen people. Input is always welcome! Comments, good / bad /yes /no? Thanks in advance!
Old Jun 11, 2002 | 10:00 PM
TBI305Camaro's Avatar
mine is getting pretty bad. a year ago when i bought the car it didnt do it. now its pretty bad i want to replace them but i dont want to replace heads because i plan on swapping in a 350. i have access to a air compressor and fittings so it shouldnt be to hard to do.
Old Jun 11, 2002 | 10:01 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
here is one link
https://www.thirdgen.org/techbb2/sho...hreadid=110714
and another
https://www.thirdgen.org/techbb2/sho...ht=valve+seals
Linson
Oct 24, 2025 02:00 PM
Lbibb
May 5, 2016 12:00 AM
gord327
Oct 3, 2015 01:25 PM
bschmale66853
Sep 30, 2015 08:11 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
