LS1 intake on a regular small block
Old Jun 11, 2002 | 08:09 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
ok, so you can put a LT1 intake on a regular small block right.
so...
does anybody modify LS1 intakes to fit onto a regular small block...
or...
how similar is the LS1 to the LT1?
just thinkin
andrew
Old Jun 11, 2002 | 08:18 PM
89Irocz23's Avatar
im almost positive you cant. I think thats its not even a 350 any more. the ls1 is completely different than a lt1. Bolt holes are different and everything. maybe some ppl can back me up on this stuff.
Old Jun 11, 2002 | 08:22 PM
Car: 1985 Z-28
Engine: a big one
okey dokey...
I wonder if i could somehow fabricate my own "ls1" style intake that can fit on my car.
I think i can scrounge up some aluminum to do this...
If i do, what would be an ideal intake runner length/size for a 400-427 small block? i even betcha you could probably be able to use some of the TPI stuff for this. and i have an old edelbrock victor intake i can use for a base and such.
thanks
andrew
Old Jun 12, 2002 | 07:30 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
No. No you can't.
Old Jun 12, 2002 | 09:40 AM
Guest
Guest
Posts: n/a
It'd be a physical impossibility unless you also used the heads, which wont directly bolt up.
I'd forget duplicating the intake. Most of the power potential from the LS1 is in the heads, not the intake.
Old Jun 12, 2002 | 10:22 AM
Vader's Avatar
Originally posted by Ace_Murdock
okey dokey...
thanks
andrew
Ace,
Some of the calculation for the "ideal" runner length is going to depend on your specific engine parameters, like valve timing, intended RPM range for peak charging effect, and runner cross sectional diameter. I can probably fins a formula for you to calculate if you're really interested.
Old Jun 12, 2002 | 02:43 PM
burnoutrpm's Avatar
agreed the heads are the big key on the ls1's not to mention the sequentail injection system....extremely efficent!
to your first question i also was wonderiong and the answer is no they use different block altogether, 15 degree heads and a cathedral style intake runner. if you did make one it'd still be limited and be pointless on the standard 23degree heads.
Old Jun 13, 2002 | 12:01 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Short answer no, long answer yes.
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
