Will this hurt anything
Old Jun 12, 2002 | 04:47 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Hey all I have a question for ya.......I have removed my TBI for Carb and I am keeping my in tank pump. Is there any problems with me using a constant 12 volt supply switched on when the key come to the on position. I am using the 12v. sending into the stock fuel pump relay and the pump will only run when the key is on. I am also using a return 3 port regulator so its not a dead head regulator.
Brian Felts
Old Jun 12, 2002 | 05:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
From a safety standpoint, you should have an oil pressure switch in series with the power. With a carb, you should be okay without a timed relay for starting, although you may have to jumper that switch if the bowl is empty to get it started the first time. Or, with an old-style starter solenoid, run a parallel power path from the 2nd terminal.
Old Jun 12, 2002 | 05:16 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
What about the distributor and TC LU.
Old Jun 12, 2002 | 05:22 PM
No all the othe computer stuff have removed some time back, I have just used the computer to run the pump for a few months now and am looking to do away with it all together. The T/C will be the next thing........I think I am going to get the B&M kit for it.
Brian
Old Jun 12, 2002 | 11:18 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I would put a fuel regulator in the fule line, i'm not sure what pressure is its but i'm sure it is over 6 psi for a carb.
Old Jun 13, 2002 | 01:57 PM
Yeah I already have the regulator, I keep mine dialed in at 6psi and it seems to run at its best. I am getting a higher flow rate pump so I may be able to back the pressure down some.
Brian
redmaroz
Apr 25, 2017 07:14 AM
92GTA
Apr 9, 2016 07:39 AM
Stroopwafel
Sep 11, 2015 06:38 AM
91REDZ28VERT
Fabrication
Sep 3, 2015 02:28 AM
86White_T/A305
Aug 17, 2015 12:16 AM
