Installing Throttle Spring
Old Jun 13, 2002 | 02:02 PM
Zuckuss88GTA's Avatar
Ok i Bought a throttle spring for my car and Need some help installing it. Has anyone done this before?
Old Jun 15, 2002 | 09:40 AM
Vader's Avatar
Zuckuss,
If you have an original spring for a TPI throttle body, the installation will require you to remove the TB from the engine, grind the stakes from the throttle belcrank plate/shaft, remove the belcrank and spring, then stake/spot weld the pieces back together.
An aftermarket return spring will be a totally custom installation. Sorry, not much help there.
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
