New mechanical fuel pump not working...
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
I just got done with a cam install and installed a new mechanical fuel pump. I set the fuel rod on the lobe as it was before and put the plate back on as it was before and all that but it doesn't seem to be pumping. Is there anything in particular that I should realize I forgot about the installation? From what I could tell you just take the rod out, put it in to rest on the cam lobe and the side of the plate then pop in the fuel pump and bolt it on (with much effort) Am I right? Am I incorrect? I would GREATLY appreciate some help with this as I want to get the cam broken in before the assembly lube runs off or something along those lines :-/
Re: New mechanical fuel pump not working...
Engine: 2.0 turbo
Transmission: m5
Yea I thought of that too yesterday, I had them clamped I thought MAAAAYBE it might be collapsed internally so I replaced the line. Still no gas... I should have pressure in the tank and everything, had a full tank etc etc. I think my pump is just dead. What do you expect for $10...
Transmission: 4L80E/4L80E
Are you completely sure the pump lever is on the end of the push rod and not beside it?
Engine: 2.0 turbo
Transmission: m5
I checked again and it's both correct unless they have a larger return line than sending line on the pump for some reason, although knowing these bargain pumps it's always a possibility...
I think I might just say forget the whole thing and buy a quality pump like a holley and get a malory 3 port regulator...
This stupid fuel pump MUST be dead even after priming the engine no luck... Garbage Advance Auto parts...
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I bought a cheap mech pump. Worked for all of one day.
Ended up buying a new Delco pump.
Ended up buying a new Delco pump. Trending Topics
Loosen fuel pump bolts and push down on pump. You should feel resistance of lever and return spring in pump against fuel
pump rod. If there is little or no resistance the pump arm may
be beside rod instead of on the end of it. If pump feels "normal",
pushing up and down on the loosened fuel pump should start
to pump fuel after about twenty strokes.
theshackle
Mar 5, 2017 06:37 PM
