raising my car
Old Jun 16, 2002 | 03:43 PM
82z28122's Avatar
raising my car
what would be a good way to raise my car and still look good so that I can run true duals exiting infront of the tire using bullet mufflers. I have an 82 z28 with 350 not cfi.
Old Jun 16, 2002 | 10:18 PM
Jza's Avatar
Jza
The best way would be to install a set of new stock height springs. If yours are original, there's a good chance that they've settled so that the car is actually lower than factory even though you have factory springs.
If your installer is worth anything, he can run the duals without having to actually raise the ride height any higher than that.
Old Jun 16, 2002 | 10:53 PM
82z28122's Avatar
well my dad has ran this exhaust on his gto and he says it will need raised to be ran like this because there is only like 4 inches between the ground effects and ground. I think this exhaust will sound mean.
Old Jun 17, 2002 | 02:45 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
it can sound just as mean exiting from the back. camaros are sports cars, not muscle cars. i think it would look goofy jacked up. i would think you can run true duals to the back but if not, and you really want them, lift it.
Old Jun 17, 2002 | 12:51 PM
82z28122's Avatar
yes but I would really like to have something differant, and my car is pretty low in the first place, and this will be a street/strip car.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
