replacing one piece rear main seal
Old Jun 16, 2002 | 09:35 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
how hard is this to do??
the tranny is already out
is there any special procedure to remove the old one and put in the new??
i took a look behind the flexplate (which i am having problems getting off because it rotates when i try to loosen the bolts) and the RMS looks pretty ragged
thanx in advance
Old Jun 17, 2002 | 02:54 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
as far gettin the flexplate off, wedge a screwdriver handle, block of wood or the like between one of your accessory belts and a pulley and when you crank on the flexplate bolts, the block will wedge itself and the tension on the belt will keep the engine from turning.
to get the seal out, unbolt the carrier thing (not sure what it's called), you may have to loosen the oil pan, can't remember. pry out the old seal, oil up the new one and press it in. i placed a 2x4 on it and pounded it in evenly. now put everything back together.
Old Jun 17, 2002 | 05:07 AM
thanx
Old Jun 17, 2002 | 07:11 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
It's designed to be pryed out without loosening the oil pan or the aluminum housing.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
Reborn756
Sep 4, 2015 03:42 AM
Leggman1
Aug 6, 2015 04:15 AM
