Rims, Tires, offsets, lug nut spacing....???
Whats up guys?....alright I have a few questions for all of you about tires and rims.....my first question is...Whats the biggest tire i could fit on a 15x6.5 inch rim?....I dont want something huge but I want something a littl wider than what i have....my second question is...What is the spacing between each lug???...or how do i find that out???....was it a standard size on all camaros???...these are my first few questions i am sure i will think of some more but the answers to these right now would help me out a lot.
Chris
Chris
Chris,
The standard lug pattern is 5 x 4-3/4".
About the widest tyre that can be fit on a 6½" wide wheel is a 225. Any wider, and the sidewalls will be pinched to the point where the tread will be forced into a crown at its center. As the aspect ratio of the tyre increases, the width section can be increased since the taller sidewall can flex more without crowning the tread. You might be able to get away with a 235/75-15, but with an aspect ratio of 50% (50-series) the maximum tread width would have to be reduced to 225, or a 225/50-15 might be the widest. On a 7" wide wheel, you can squeeze a 235/50-15, and on an 8" wheel, 245-255 can fit in a 50-series.
You should be able to use up to a 40mm offset, but don't go below 20mm on the front wheels because of steering arm clearance limitations.
So you guys are pretty much saying try to get wider rims?....I didnt want t go all out on rims and tires so when i seen these rims i had to see what tires i couldfit on them....i think ill tryfor 16 inch rims and see what happens...so i could fit 235/50 on a 16x7??....will they be wider tham my 235/60/14??...and can i put the 235/50in the front?
Chris, the numbers for tire size break down like this. If you have a 235/60/14 for instance, the 235 is the width of the tread section in millimeters. The 60 means 60% of the width (235mm) from the tread to the rim, and is called aspect ratio. And of course the 14 would be the rim diameter. a 235/60/14 would be the same width as a 235/70/15. You have to watch the aspect ratio or you may end up with tires that are really tall and will mess up your speedo. I'd say in your case, you would be happier in the long run (and safer) finding a set of 16 inch wheels and going with a wider 50 series (the second number
) tire. The shorter sidewall really helps the handling out. Hope this makes some sense and helps.
) tire. The shorter sidewall really helps the handling out. Hope this makes some sense and helps. Thread Starter
Alright i knida get what your saying.....so i should get a wide tire but a short sidewall??......how about this...instead of trying to explain it to me why dont you guys just tell me what size tires will fit and look good on 16x7 inch rims....this way i could just go to the storeand veify everything is right....everybody just give me a size
Hotrodboba400
Dec 10, 2019 07:07 PM
rb85TA
26
Sep 14, 2015 10:29 PM
