Valve adjustment...passenger side
Old Jun 17, 2002 | 11:12 AM
Forgiven's Avatar
I need to adjust the valaves on the passenger side of my engine.
Can I buy some hose and bypass the heater control valve (?) that sits right on top of the right valve cover?
Also would it hurt the smog pump to run the motor with some piping removed?
This is also in the way on the right side. I would guess this would be fine.
I appreciate your help!
Thanks,
Ernie
Old Jun 17, 2002 | 11:35 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
The smog won't hurt anything. I just tie everything up out of the way.
Old Jun 17, 2002 | 11:53 AM
Forgiven's Avatar
Free Bird:
Thanks for the reply.
Do you also tie up the heater valve and hoses?
I guess there might be enough free play to do that. Man they look so close to the VC that I think it will be nearly impossible to remove it without doing something drastic with that valve and those hoses.
Ernie
Old Jun 17, 2002 | 06:42 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I'd just remove the heater hose from the throttle body and flip the whole deal up under the pass wiper blade.
You can also tidy up the compartment by running hose up around the radiator. Just watch the belts, zip-tie it real good.
Out-Cast
Sep 3, 2015 09:05 PM
db057
Aug 22, 2015 08:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
