always takes 2 cranks
Old Jun 17, 2002 | 04:03 PM
uidzer0_z28's Avatar
Hey everyone,
I was wondering if anyone has any insight as to why my 82 camaro (305/cfi) always takes 2 cranks to start up, it never starts on the first one and it always starts on the second, not a really big deal but kind of embarrasing =(.
thanks,
Ben
Old Jun 18, 2002 | 01:40 PM
anyone?
Old Jun 18, 2002 | 05:49 PM
camaroluv's Avatar
Hey
I have a cross fire injection and it takes off one the first crank but seems to turn 0ver a few more time than my 87 did.
sorry this dont help
Old Jun 19, 2002 | 01:22 AM
jeffs82z28's Avatar
IMHO, you are dealing with a horizontal tunnel ram with a HUGE plenum, and it takes a little time for enough fuel to get into the manifold to get some to the combustion chambers.
Try letting it crank till it fires.
A friend of mine has an 83 with the CFI, and he does that "2 crank" thing also. ( he won't listen to me when I tell him to let it crank either)
Old Jun 19, 2002 | 01:34 AM
uk89camaro's Avatar
2 cranks from cold or hot?
Can't see the problem with two cranks from cold!!
Old Jun 30, 2002 | 10:30 PM
REBIRTH's Avatar
It takes my 82 Trans Am CFI about 2½ Cranks until it starts. When it's hot on the other hand, it starts in about 1½ Cranks.
Old Jun 30, 2002 | 10:33 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
ha! two cranks... i was happy if i could get my old 305 to start at all without the batt going dead. Lousy compression i guess. new 350 takes three cold.
Old Jul 1, 2002 | 10:48 AM
Rudy's90irocZ's Avatar
my 90 iroc with a 305 tpi would take about 3 cranks to start and then when it did turn over it would rev to about 1200rpm then down to 700rpm and die. I would crank it over and start on the first retry. Fluctuate a few times in the low rpms and then settle down to about 900rpm. I took me a little 500 mile trip on the car and now it starts fine on the first crank. Go figure...
Old Jul 2, 2002 | 01:11 AM
REBIRTH's Avatar
That sounds like mine. It would raise to 1200 or so, then drop to about 400, then fluxuate....probably due to the timing being advanced.
Old Jul 2, 2002 | 09:43 AM
Merlin's Avatar
Maybe you could try to slow down the starting process a little. Turn the key to RUN and let the fuel pump pressurize the system for a couple of seconds before you crank the engine.
As for the hunting idle after start up, it sounds like the IAC and throttle body might benefit from a little cleaning.
Old Jul 2, 2002 | 09:57 AM
REBIRTH's Avatar
I'll try that Priming trick, it will probably help out.
The Idle problem is probably due to the Timing being advanced and also I got the 2 Throttle Bodies cleaned. I threw some Injector Cleaner in a month ago, but still does the same thing.
Oh well, i'll wait till I get a Tune-Up and the proper Timing and see where i'm at then.
Thanks Merlin!
bryan623
Mar 22, 2021 06:43 PM
mddaniel
Sep 8, 2015 05:16 PM
Reborn756
Sep 4, 2015 03:42 AM
WIzmo
Aug 30, 2015 02:30 PM
