hydraulic roller
Old Jun 17, 2002 | 04:43 PM
highhat's Avatar
hydraulic roller
Do the 87 n newer 5.7's have roller lifters or just hydraulic?
Old Jun 17, 2002 | 05:10 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
If its a F-body or Vette YES its a roller however the truck blocks were flat tappet.
Brian
Old Jun 17, 2002 | 05:48 PM
immortal's Avatar
Forgive my newbie ignorance, but how is a rolling lifter better or what does it do that the non rolling one does not. thanks
Old Jun 17, 2002 | 06:23 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
High points of the hyd roller over a flat roller:
- Much longer lasting due to less friction
- Less friction = more power
- Roller can follow a steeper ramp, therefore the ability to:
- Open the valve faster
- Open the valve higher
- Less advertised duration with more @ .050" = smoother idle
- No break-in procedure
- New cam can be used with old lifters, no "matched wear" to worry about
And the disadvantages that I can think of?
- Higher priced
- Some aftermarket cams require bronze distributer gear which wears too fast on the street IMO, especially with a HV/HP oil pump
- Heavy *** lifters require crazy springs and/or rev kit if you're shooting for high RPM's (This only true for Hyd Roller, not solid roller, although you still need some good springs as solid rollers usually have some massive lift figures )
Old Jun 18, 2002 | 10:18 AM
immortal's Avatar
Thanks for the info, i heard alot about the rolling one being better but i never knew why until now.
Old Jun 18, 2002 | 11:56 AM
highhat's Avatar
Thanx
Thanx for the info :hail:
Old Jun 18, 2002 | 05:57 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Brian
NO. The truck blocks were equipped for a roller cam but did not come with them until '96.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
