Cat rattle- would it happen all the time?
Old Jun 20, 2002 | 01:16 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Just got a call from a friend's father; he says he's got a rattle under his '87 Camaro that he can't find. He says it's on the right side, and sounds like it's near the cat, but he doesn't think it is the cat. The car rattles when you first start it up, and will rattle in park, or, when it's in drive with the brake on. He says if he rev's the motor up a bit, the rattling stops. He says, too, that if he turns the Camaro off, he hears the rattle after the motor stops.
I was thinking the catalytic convertor bed had broken up, and was rattling- but wouldn't it rattle even worse when he raised the RPM's? My only other guess is that the cat's hanger or heat shield has loosened up.
Old Jun 20, 2002 | 01:26 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Could be heat shield or cat. Another possibility is the starter drive is not retracting after the engine starts & finally does after the engine gets revved a few times.
Old Jun 20, 2002 | 01:52 PM
1986redbird's Avatar
its almost certainly the cat, I had the exact same problems with my car when I got it, try unbolting the back of the cat and looking in to see whats up. when I opened mine up I found every thing was gone so I figured cool, I wont have to gut it my self, then I found all the pieces in the pipe going to the muffler.
Old Jun 21, 2002 | 09:33 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Thanks for the info guys! I'll get to look at the car this weekend; I'll post what I find!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
jharrison5
Aug 19, 2015 05:53 PM
