MAF Relays
Old Jun 20, 2002 | 02:05 PM
felo72's Avatar
MAF Relays
I have three relays on the firewall, it's an 86 IROC, TPI, I think in order from left to right looking from the front of the car is MAF burn off, fuel pump, and the other MAF relay (I can't remember what it's called). All of the relays have the same part number on the top. Should I assume they all use the same relay? I have two relays from AutoZone and they were both listed for the burn off relay, but the part numbers are different. Has any one ever changed one, and if so could I have the part numbers to get the right ones for all three if possible? AutoZone and the dealer all told me they have to compare it to the original one, but they all look the same, even the new ones.
Old Jun 20, 2002 | 02:44 PM
howardhughes's Avatar
in my experences i found those relays to be the same.the reason you might have gotten 2 different part numbers from autozone is that's the way the manufacturer of the relays set it up.i bought a power door lock relay once and it said on the box"compressor relay"but it worked.good luck.
Old Jun 20, 2002 | 03:11 PM
felo72's Avatar
I thought it might be considered a backup stock part number but wasn't sure. Thanks.
Old Jun 20, 2002 | 04:32 PM
anytime.you're welcome.
Mark_ZZ3
May 24, 2018 01:02 PM
thunder57
Nov 7, 2015 02:28 PM
racereese
Oct 3, 2015 03:46 PM
