why does my car stuble when I turn?
Old Jun 20, 2002 | 09:41 PM
Joshua Leslie's Avatar
Hey!!!!
my car has an Edel. 600cfm carb.
ok, so, say im going 45, and I slow down to turn into a subdivision, so I slow to about 10 or 15 while turning, the engine stubles and hesitates really bad, and almost stalls out everytime I turn.
I am thinking the carb. floats? If so, how do i adjust these?
Old Jun 20, 2002 | 09:45 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Do you hear any funny noises? I would say check the power steering fluid or belt.
Old Jun 20, 2002 | 09:50 PM
LarsZ28's Avatar
Yep, check the pwr steering fluid, and the pump..
Old Jun 20, 2002 | 10:10 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
If I'm not mistaken edelbrock doesn't work on a float system. So count that out. As far as the pwr steering pump......maybe. Carbs naturally suck when it comes to cornering and what not. They rely on gravity and whatever vacuum the engine has created to pull the air and fuel in. I would try tuning the carb and making sure the idle screws are adjusted right. While your at it check the ps fluid.
Old Jun 21, 2002 | 06:39 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
I get the same thing...but usually only on long sweeping curves at fast speeds....Those speed Demon carbs are looking pretty good. I think thats the way i'm going with my 400ci.
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
