can i use teflon on tranny cooler fittings??
Old Jun 21, 2002 | 03:00 PM
breathment's Avatar
its not on my f-body, but on my parents jeep grand charokee.. i replaced the radiator yest. and now the tranny cooler fitting it leaking, i don't know if you should use teflon on those type of fittings.. or just tighten it up more..
Old Jun 21, 2002 | 04:35 PM
ZZsmpch's Avatar
I never use the stuff anywhere it can get into something that will clog like a tranny or brake system. Try to tighten it more, and if that doesn't work, check the flare to make sure it is OK.
Old Jun 21, 2002 | 04:55 PM
Marc 85Z28's Avatar
Don't use the old style Teflon tape, it eventually breaks up and gets into the fluid. Insted, use a Teflon O-ring.
Old Jun 21, 2002 | 05:58 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
If you're talking about th fitting that goes into the radiator (NPT) then yes...
If you're talking about the flared fitting that couples the line to the fitting on the radiator, then no you should not, reason being is that you'll only be doing a bandaid fix, which will eventually leak again.
You should be able to tighten the fitting snug, then an 1/8th to a 1/4 turn more (holding the "nut" side of the fitting on the radiator) and it should seal properly, if not...look for a crack/split on the "flare" of the tranny line, or a burr on the taper of the fitting.
The tranny line is a flared line, designed to be sealed via pressure of the nut, not with tape/sealant...so if it's leaking there, look for damage and replace as needed.
Old Jun 21, 2002 | 11:25 PM
breathment's Avatar
alright, it only needed to be tightend up a little, and it was flared..
thanks alot guys!!
Magman
Sep 12, 2015 10:43 PM
spaigo
Aug 21, 2015 07:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
