LT1 350 roller lifters in old 400ci
Old Jun 23, 2002 | 12:19 AM
lukerene's Avatar
Car: 1982 t top,,z/28,
Engine: 409ci vortec
Transmission: all steel t700r4,1300 stall yahooooooooooo
will the lt1 factory roller lifters fit the older type 400 ci engine,,i notice the advertisment says will fit roller blocks,,,and efi ,,,,fuel injected engines,,,,,i have a 1972 400 i intend using a new cam in,will i need anything else besides the factory roller lifters,,, i will be using vortec heads,,,,
Old Jun 23, 2002 | 12:44 AM
Swapmaster's Avatar
They won't work. There is nothing to keep them straight on the
cam lobe. You need aftermarket rollers with the bars that hook
the lifters together and keeps them from turning in the bores.
Old Jun 23, 2002 | 01:19 AM
lukerene's Avatar
yeh thought so ,,,i have seen them coupled together,,,,just thought gm might have kept the internals the same like the early engines ,,lifters,,cams, pushrods,, these newer type engins are not interchangable,,,toooo many different bits,,,,
midge54
Dec 27, 2019 04:14 PM
MoJoe
Sep 24, 2015 09:12 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Eric-86sc
Aug 24, 2015 09:01 PM
