just pulled a 82 lg4. how should i rebuild it?
hi guys. i just got a lg4 motor and 4 speed saginaw out of a 82 camaro z28. believe it or not the motor only has 37,654 mi on it. how should i go about rebuilding it? i want to get low 14's with the motor. what mods should i do to it. im gonna start tearing it down this next week.
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
its possible with the 305 , find a good machine shop......talk about the possiblities........take your time and research it and you may get even faster.......mine runs high fouteens with ****ty carb and not much work........and i got a 305
Axle/Gears: 3:08
dude......one more thing......shorten the signature......or at least only post it once per topic..........people with slow connections (not me) will be waiting foreverfor it to load.....lol
Car: 1982 t top,,z/28,
Engine: 409ci vortec
Transmission: all steel t700r4,1300 stall yahooooooooooo
just buy a car with a V8 ,,,drop a crate motor in it,,,turn the key and drive,,,,LT4,s are good value,,,,,i think this is your solution,,,,forget weld tech heads and no2 ,,, just turn that key,,less you got $$$,,,even a budget cost money,,,and you will find you want more,,,,before you know its out of control $$$$,
To get 14s out of that LG4 I'd suggest getting a good cam from comp cams, some aluminum L98 heads, roller rockers, a decent set of headers and a cut out, and a new torque converter for that tranny that stalls at least around 2500rpms. A lot of 305s run the LT1 cams with moderate success, but I'd suggest something a bit more aggressive if you want low 14s(and obviously get a flat tappet, not a roller cam..just wanted to show you what you should aim above). The aluminum L98 heads are good because they already have screw in studs. If you had a v6 in the car before, it's probably got decent gears in the rear. I wouldn't touch the short block as long as it's in decent condition. Hopefully that's not 137k miles :\ A little NO2 will help
If you've still got money, some subframe connectors and some nice LCAs would do the car wonders.
